4020 battery
pdz180
05-21-2005 08:46:05
I need a little help here. My right side battery (24 volt system) was shorted out. I replaced the battery, and she started right up. I went out three days later and the right battery (new one) is dead again. Does anyone know where to start looking? Thank you for your help in advance.
msb
05-21-2005 19:26:12
 Re: 4020 battery in reply to pdz180, 05-21-2005 08:46:05
Pull the end off the starter and see if the thrust washer is worn enough to let the commutator hit the end cap.If so, you will be able to see where it has arced on the end cap.Its a rare occurence but I have seen it happen before.
Gerald J.
05-21-2005 09:05:02
Something that loads the right battery only (right side lighting probably) is left on, maybe by a bad switch, or there's a wire for that side of the electrical system that has a hole worn or chewed in the insulation that lets the wire touch ground. That problem could also be in the generator or the starter.
Charge up the battery. Disconnect the ground from the battery, connect a 12 volt test light between that floating bettery ground post and the frame. The light will show leakage current from the hot wire on that side. Disconnect pieces and wires until the light goes out. The leakage or ground is in the one that makes the light light.
It takes logical troubleshooting, there is no one device that always fails.
Gerald J.
