Apology for Remarks Made
Pat Browning
05-21-2005 05:30:51
To Frank in Tallahassee -- I write this note to tell you that I sinserely regret my recent post in response to a post of yours. While I believe I had a good arguement, I used a tack that was not in good faith, and seek your forgiveness. (PatB)
F-I-T
05-22-2005 15:04:19
 Re: Apology for Remarks Made in reply to Pat Browning, 05-21-2005 05:30:51
Pat:
Apparently your apologies last shorter than 24 hours, as you replies get more acidic after you apologiy postings. Based on you reply to the oroginal post it would appear that you are retracting your heart-felt apology from above, then. Anyway, here's what I posted there, buried a page back now.
If the less fortunate ones without access to the internet are the ones you are yearning to service, how are they going to hear about your book via an internet message board? I'm a bit lost here.
Pat, here's what you are missing. There are a lot of folks here that have been helping folks fix tractors on this and other boards for a long time. I've been around here for five or so years and I'm a short timer. Tractors were getting fixed before us and they'll get fixed after us. Join in, but don't expect that if you paid to publish your own writing that you will neccessarily receive the mantle of expert on everything "H". A person who pays to have his own works published is no more than a rentor of a Xerox service. The content might be of value, but no one other person, no publisher, no editor, no buyer of content, has judged that work to be of merit. Until it has stood the test of time and has been deemed to be worthy of publication and distribution, it is merely a flyer. J.R.Hobbs is a noted author and regular contributor here and on the other board, he does not mention his collective works in his posts unless asked. I still maintain that you just like to hear you self blather about your book and that that somehow makes you think you are an "H"pert. Well, fine. So be it. But I can tell you that I own my fourth "H", and I know how to set up the carburetor, and I know how to set up the magneto, and I know the differences between synthetic enamel with and without hardener, acrylic enamel, with and without hardner, and base coat/clear coat applications. I have also written about these and other topics and others on these boards many times, and guess what, I probably learned much of what I know about them by starting a thread asking the question like "What can you tell me about XX". Fortunately for me, some truly knowledgeable individual like a Clooney or a John T took the time to share their experienece and theory and taught us all. They did not just point me toward their book.
If the message boards degrade to the point where all information is to be contained in "For Pay" pamphlets, then the questions will only consist of things like "Can anyone tell me where to go to buy the answer to XX".
That will be a sad day.
Frank Boerger
Mike M
05-22-2005 12:21:48
Aw come on guys it was just getting interesting. I was just waiting for FIT to tell you where to put that gauge. LOL
F-I-T
05-21-2005 18:48:00
third party image
Ok, Pat. I will say I cannot recall being so challenged over my opinion of how to install a gauge or why a particular hole was appropriate.
And, not to work it over, really, the only point I was trying to add is that I think the oil pressure gauge got the hole that was left over, not the hole of first choice. I think the temp gauge got the upper one as it is easier to see so the operator can read it better as he has to refer to it more often if he is burning distillate.
Also, if you ever paint a dash panel separate, try installing the gauges and wiring first. It really helps. Makes it modular. That's the way they did it when they got into the more complicated models like the 70D's and such. I did that way on my VAC Case and 70D. Lots easier to wire everything but the long wires on the bench.
Pat Browning
05-22-2005 05:12:08
 Re: Apology for Remarks Made in reply to F-I-T, 05-21-2005 18:48:00
The detail in your panel looks nice. I have always felt that if the body parts of a tractor look good, the discerning eye sort quiets down in a hurry.
So far as mounting the oil line on the JD "H" is concerned, with the gauge already mounted, all you need is a new line and a small crowsfoot to tighten it up snug, and you are in like flint. To avert risk of leaks at that stage of final assembly is well worth the price of a new line and a couple new fittings.
Do you have plans for your JD "H" any time soon? BTW, go to >Link
Thanks for coming back to me. Have a Great Day! (PatB)
txgrn
05-21-2005 05:58:31
Don't know the circumstances, but you are a big man for making your apology. I sometimes do things that I regret later on here. Really makes me feel bad later.
So what I have decided to do is that if I read something that I feel like responding to in a negative fasion, I sleep on it. Seems the next day, I see it in a different light or see where I am not perfect either and blow it off.
Case in point. Hydraulics....lots of folks spell it hydrolics. Incorrect of course and the more I see it the more prone I am to spell it incorrectly also.....but then I do things like saying "dunno" for "don't know" and other such things. So I just pass on it and go on about the subject matter at hand. Besides, with no spell check on this site, I mispell things too.
Mark
