I am rebuilding the powershaft drive assy on my 730. Have a couple of questions...1. I knocked out the bushing on the pump and the double seal before that. Ordered new bushing. When it came in, the new bushing measured same bore or real close to old one. That is on a 45 year old tractor which I don't believe has ever been down in this area. Does that compare with experience of any of you who have done this before? 2. Pump seal was rolled over at one point and looked to me to have been leaking from day one. Just throwing this in...no question. Have new twin seals to replace old double by putting them back to back to seal both directions. 3. Pilot bushing still has good brass on it for clutch pack. Didn't knock this out because looked okay...was $30+ and isn't that hard to get to. I did notice that there is quite a bit of slop between bushing and hardened clutch shaft end. Is this supposed to be a loose fit? 4. Finally, it looks to me like clutch is made solely by detent in foot pedal mechanism engaging along with proper rod adjustment. Saw nothing in internals of clutch pack that enhances engagement. Do I have this right? And brake....is brake latched solely by the clutch pedal mechamism going over center in the other direction? Thanks. Clutch pack was worn out...back three plates were worn to steel on steel. End plate facings were gone and brake plate was just about shot. This thing had a lot of use, though, and guess I shouldn't be surprised at how worn it was.
