4230 transmission
R. John Johnson
05-20-2005 10:42:58
I've noticed it grinds shifting from 2 to 3, not from 3 to 2. Seems worse in C and D ranges. If I wait 4 or 5 seconds it will shift without grinding. I assume that the sycronizers are worn out. I don't intend to do anything right now, but what is needed. I know the cab will have to come off and the tractor split.
PS I took the junk aftermarket seat off and put a personal posture seat out of a 8430 on the existing suspension. MAJOR improvement.
John
txgrn
05-21-2005 06:07:49
 Re: 4230 transmission in reply to R. John Johnson, 05-20-2005 10:42:58
I sometimes have a noise when I shift. I find that If I make slow deliberate shifts, I don't have the problem. It's when I shift fast, but sloppy if you know what I mean....like go half way and stop before going all the way into the next gear position. With 4000 hrs on the tractor, I wouldn't suspect syncronizers wearing out yet. May be the way the linkage is set up between the cab and the side of the tranny.
Back to my oil pressure fluctuation. After the comments to replace the gauge or sender (from folks on here), yesterday I watched the gauge as I started the engine. Shure enough, the pressure came on very erratically; like wiggled in the first quadrant on to the center then paused for a second and popped over to the 2:30 position. Looks like a sender. So now that I know (think I know) what's wrong, I'm not concerned about it.
Mark
cannonball
05-21-2005 05:11:14
had our top shaft redone about 4 years ago..they did not remove cab..just supported it from the top and remove trans section..take floor cover out and remove bolts inside..they rolled rear back..to do two speed you need to remove cab....have nice day may god bless
