Chips out of final drive gear.
Kurt_JDB
05-19-2005 17:59:23
I recently obtained a used final drive gear that I plan to put in my "51"B" The gear in the my "B" was damaged by an incorrect brake pinion. I bought it sight unseen. Upon close inspection, I found this new gear had a chip broken off the side of one tooth, and a chip out of the middle of 3 or 4 other teeth. Other than that the gear looks good.
Is there any problem using this gear? Should I file the edges where it broke? I only paid $10 for the gear, so I don"t have a lot in it.
thanks,
Kurt
buickanddeere
05-20-2005 07:52:34
 Re: Chips out of final drive gear. in reply to Kurt_JDB, 05-19-2005 17:59:23
Did you purchase both the driving and driven gears? They are wear pattern matched. Mixing gears can make for some extra noise.
F-I-T
05-20-2005 08:03:51
 Re: Chips out of final drive gear. in reply to buickanddeere, 05-20-2005 07:52:34
That's kind of tough to do since the driving gear is the differential and the driven is the bull gears. Have to change the diff to keep it a set. Since these gears are straight cut, and run so slow, I wouldn't worry too much about them. They'll wear in in the next 50 years.
Frank
buickanddeere
05-20-2005 11:59:39
 Re: Chips out of final drive gear. in reply to F-I-T, 05-20-2005 08:03:51
It would be a simpler swap to just undolt the axles/diff off the tractor and replace with a good one if everything was worn. We changed out the 80's bull gears. The "new" ones are almost as noisy the old but at least they are all there.
F-I-T
05-20-2005 13:54:13
 Re: Chips out of final drive gear. in reply to buickanddeere, 05-20-2005 11:59:39
I hear you, but straight cut gears will never have the wear memory of helical cut or bevel bears. Those I agree that you need to keep matched, especially rings and pinions. These old rearends just turn so durn slow.
Kurt_JDB
05-20-2005 14:13:54
 Re: Chips out of final drive gear. in reply to F-I-T, 05-20-2005 13:54:13
I"m not so concerned about noise as I am about damaging something else by using a gear with a chipped tooth. I am not that knowledgeable about gears, this is my first tractor.
The existing gear teeth have really been worn, sort of a cup shape cut out on each tooth by this wrong brake pinion gear. At some point the brake assemblies (type with a bolt on drum) were replaced with the older (bolt on pinion gear) type. One of the pinion gears was from an even older B tractor, and had 11 teeth instead of 12. Shortly after I got the tractor, I removed this brake assembly because it was very noisy. I then removed the other assembly, and found the pinion gears were different. I did more research with the parts book and found out the the brake assemblies were from an older tractor.
Do you think the differential may also have been damaged?
Kurt
F-I-T
05-20-2005 15:32:17
 Re: Chips out of final drive gear. in reply to Kurt_JDB, 05-20-2005 14:13:54
Well when you slide that bull gear out of the way you'll get a clear view of the differential and you'll be able to make that determination.
Since the brake pinion does not interact with the differentional component, I doubt that it has been harmed, but that is a guess on my part.
Mike M
05-20-2005 05:57:52
Final drive gears should not be too hard to find. I would run an ad over in the classified section and try to find a real good one.
