How much noise??
uglyoldA
05-19-2005 12:29:29
Spent this winter rebuilding a stuck motor on a '51 model A . This tractor has been on our family farm for about 35 years and has spent the last 17 sitting in a shed . Now that I have it running again , it seems to have more tranny noise than I remember . There is a whirring noise in third and a little in fourth . It has a fresh change of fluid . Is some noise acceptable ? Or do I have more work this winter? thanks george
mitchp
05-19-2005 20:14:46
 Re: How much noise?? in reply to uglyoldA, 05-19-2005 12:29:29
mine has some noise in a few gears, 2nd and 3rd are the worst, its manly from wear. A man told me that you can put a couple bottles of STP in your tranny oil and it'll make the fluid stick to the gears better and quieten it down some, didn't help much on mine though
Earl-IL
05-19-2005 17:10:45
What weight grease did you use? The grease is a lot thinner than we used in them 30 yrs ago. You can still get it but you have to shop around. Earl
Ben48A
05-19-2005 14:15:59
I have a 48" A and it seems to do the same thing. I think it is something with the 3rd/4th gear ratio. so no I think you can spend your winter playin in the snow with it.
Ben48A
05-19-2005 14:13:12
960
05-19-2005 13:29:23
I grew up on a 60 and a 3020. I still have the 60 and now have a 4020. The reason my tractors are noisier than I remember is the soundgard body on the 30 through 50 series we farm with have changed my reference point of what is noise.
CLW
05-19-2005 12:50:15
The A would have spent most of it's working life in 3rd or 4th, with 3rd. pulling the heavy load. Normal wear. I don't think you have anything to worry about. If you do fix it let me know what the problem was, mine does the same thing.
CLW
Mike M
05-19-2005 12:47:27
Hard to listen over the computer ? All tractors make some noise and all different. But on a tractor that old I have never torn into a trans. that I did not find some problems.All seem to have too much end play on the lower countershaft,some will have a few bearings with bad spots. Often you will find broken/chipped teeth from shifting without being stopped. Sometimes if you fix one that had real bad bearings they will even get more noisey because of wear patterns,but at least you know whats in there is good. It will probabally run fine for years as is. I however never was one to leave something alone.I always go pokeing around looking for problems in a tractor I was going to keep.
uglyoldA
05-20-2005 05:16:14
 Re: How much noise?? in reply to Mike M, 05-19-2005 12:47:27
I filled it with 85/140 and a couple quarts of thick oil treatment . It's probably not as bad as I think , it's just that my '46 Slantdash is all but silient . thanks George
John in IN
05-20-2005 19:17:54
 Re: How much noise?? in reply to uglyoldA, 05-20-2005 05:16:14
It's a very good idea to use GL-1 gear lube in the old tractors. Try 140 Wt. The 85/140 you used is probably GL-5. The newer gear lubes have additives that can cause damage to brass and bronze in a transmission. Look up the Chevron Inet. site, they have all the info about this.
