620 crankshaft adjustment
jdjack
05-19-2005 10:18:57
I have the flywheel and clutch off. Does the clutch go together and then installed flywheel and adjust endplay with flywheel? Also how tight should the nut on flywheel to torqued to.
How much endplay should there be. Thanks.
Mike M
05-19-2005 11:47:07
 Re: 620 crankshaft adjustment in reply to jdjack, 05-19-2005 10:18:57
I just went back several pages and see that you are the one with the too tight clutch problem. Look closely at F-I-T's picture #20 that inside thrust washer if it is not there would let your crank go over to the left too far.I think they may be around 1/8" thick ?? If when the flywheel is off if the crank moved to the right alot this washer can move out of it's groove and it may not go back in the right place and crack. At least that's how I explain the ones I have found missing and/or in the bottom of the crankcase. Set the end play within .005" to .010" and it doesn't really matter if the clutch is together or not as you use the flywheel to set it by pushing it on farther. Use the tin nut to draw it into place then tighten the 2 pinch bolts and recheck.
#20 two washers used
05-19-2005 11:49:21
 Re: 620 crankshaft adjustment in reply to Mike M, 05-19-2005 11:47:07
Both washers are labeled # 20 1 inside and 1 outside of the main bearing housing. Make sure you have both in place.
TRACTORFIXER
05-19-2005 10:37:35
CLUTCH FIRST. THEN DRIVE ON THE FLYWHEEL UNTIL THERE IS 0.005-0.010 CRANKSHAFT ENDPLAY. CHECK WITH A DIAL INDICATOR WHILE ENGAGING AND DISENGAGING THE CLUTCH. THE FLYWHEEL BOLTS SHOULD BE TIGHTENED TO 275 FT LBS. TIGHTEN THE NUT 'SECURELY' AND PEEN A SMALL PART OF THE NUT INTO THE KEYWAY.
F-I-T
05-19-2005 10:34:31
third party image
The clutch can be assembled and installed before the flywheel is installed.
The "nut" you speak of is really not torqued at all, as it is a tin/steel nut used only to position the flywheel, then staked in place. The real holding power comes from the two 3/4" machine bolts that grab and pinch the flywheel collet style onto the crankshaft. In the old days they were high-strength like a Grade 5, which were good to torque to 250 ft-lbs, but today, I like to use Grade 8, which you can take to 370 ft-lbs.
Make sure the crank and flywheel splines are clean and dry with no debris or burrs.
The factory end play was .005-.010" hot, but I prefer .010-.012".
