70D hydraulic problems continue
StuBC
05-19-2005 08:09:03
The issue is that this spring when I fired up the tractor, a stream of oil leaked from the oil return line plug that is retained in the pump housing. Nothing from the pressure line. I took it apart originally, cleaned it up and installed new o-rings and inspected the plug, is in good shape, but it has been modified/welded so that it has a JIC male plug on it close to the JD plug so a rubber hose can be used. Probably common. I posted here and received good advice which I have implemented to the best of my ability. What I pursued was thicker O-rings. I tightened it down last night and it still leaks badly. I am pretty disgusted, but I am also not sure what to do now.
Do I need to go into the avenue of new plugs. I would hate to have to buy a new housing. Are the plugs available without the steel pipe? The lines go to a spool for a loader, not the powertrol complicating things a bit more. Someone also posted about using two o-rings on the plug. Any sizes to suggest? Its a 212 standard size.
Mike M
05-19-2005 09:47:21
 Re: 70D hydraulic problems continue in reply to StuBC, 05-19-2005 08:09:03
I would think that the return line would not of needed modified only the pressure side ? Are they returning pressure oil back to the return line from the valve ? This may be the problem ???
StuBC
05-19-2005 13:55:57
 Re: 70D hydraulic problems continue in reply to Mike M, 05-19-2005 09:47:21
Mike here is what I remember (I am at work). I am not good at hydraulics. Its quite a new thing for me. My return lines goes from the pump up to my spool. Then the return oil runs from the spool and receives spent oil from the cylinders down the reservoir at the powertrol.
At the pump, the plug is what appears to be unique to JD with an Oring but they must have had a problem with the steel line that was original. So they cut the steel line off and welded on a JIC fitting so they could use newer hose. Same goes at the powertrol plug but its not leaking. I can not get the plug to not leak. But we used the loader for 2 years without problem. All of a sudden it leaked.
