1952 60 live PTO repairs
Eric Midgette
05-19-2005 07:40:02
I had trouble keeping my PTO running strong enough to drive my #5 mower and thought the clutch might need adjusting. In fact the power shaft clutch lever would drop down half way and I would get partial power but not enough to mow. Upon external inspection I found one of the tangs on the locking washer (not the bent one) chewed up on an outer corner. I decided to pull the cover for closer inspection. Problem is I don"t know what I might be looking for. I failed to do the sniff test to evaluate the fluid. Can anyone give me some pointers?
Steve Ga
05-19-2005 09:20:22
 Re: 1952 60 live PTO repairs in reply to Eric Midgette, 05-19-2005 07:40:02
I had a 60 for years,mine had the ajusting collar same as a 620.Been years ago but I took the Pto assembly off and ajusted on the bench,and you can inspect the disc. You need a tech. manual,the collar that adjust can be tightened through hole in housing.Mine had a small screw to run in and allow the collar to move,most had a tang to pull up I think. It is not a bad job to remove & replace.take your time. Is your linkage engaging all the way?
