630 won't stay running
Kerwin Graber
05-18-2005 20:15:21
My 630 will start with the choke on, run 10 seconds and quit.I wait a few seconds and try again,same thing, starts and quits.Gas is flowing to the carb and when I take the bowl off, gas runs out of the bowl.I took the carb off and blew air through every passage I could see but still does the same thing.What is going on?
Kerwin
ET
05-19-2005 06:59:18
 Re: 630 won't stay running in reply to Kerwin Graber, 05-18-2005 20:15:21
I think your resistor for the ignition is bad. When you push the starter button it bypasses the resistor and the tractor starts. It shuts down when you quit cranking because the resistor is bad.
Mike M
05-19-2005 05:13:28
I had one act very strange on me turned out the little rubber washer in the fuel bowl was staying stuck to the top of the bowl and not dropping down with the stem. This causes too little of flow. Worth a quick check. I have also seen lots of junk packed up inside of the passages of those auto shut off bowls.
Kerwin Graber
05-18-2005 20:27:18
The shutoff opens when I start cranking
Kerwin
tyho
05-18-2005 20:39:53
 Re: 630 won't stay running in reply to Kerwin Graber, 05-18-2005 20:27:18
Are you sure it is keeping the bowl full. If the shut off is working then the float needle may be clogged with some dirt or grass. You might pull the bowl right after it dies and I would bet that the bowl is empty.
tyho
05-18-2005 20:19:28
The bowl is not filling up fast enough. I would bet the auto shut off is not working. Try putting a small rock or nut in bettween the gas tank and the top of the knurl knob. Then let it set for about 2 min. then start her up and see if she will run then. If so you need to repair the auto shut off bowl.
TRACTORFIXER
05-19-2005 10:43:38
 Re: 630 won't stay running in reply to tyho, 05-18-2005 20:19:28
Try putting a small hose barb in the bottom of the float bowl. Attach a 18" piece of clear vinal hose to the barb. Hold or tie up the hose so the exposed end is at least higher than the carb. Push in of the knob on top of the sediment bowl to fill the float bowl on the carb. Then watch the fuel level in the hose to determine if that is your problem.
TRACTORFIXER
05-19-2005 10:42:55
