Hydraulic Problems with 310A John Deere Backhoe
Hyman Boyd Anim
05-18-2005 18:54:22
I was burying a cow. I was digging when the bucket would not lift out of the hole. I got a hydraulic repair company to fix it. They put a new pump in the front of the backhoe next to the radiator. The backhoe still would not work. Change the filter next to the transmission. Backhoe would not go forward or backwards. The mechanic took a line loose. Fluid just ooze out no pressure. The mechanic said he did not know what was wrong. I had to pay company $2450.00 for nothing! He did no pressure check before he took off pump. Ihave no manual. Before burying the cow, Backhoe was working great. Please help !
Thank you,
Junior Boyd
Jonathan in MA
05-19-2005 02:54:30
 Re: Hydraulic Problems with 310A John Deere Backho in reply to Hyman Boyd Animal Farm- , 05-18-2005 18:54:22
...just another reason why I don't bury cows ...but anyway... On the right side of the transmission case just above where the vertical mounted transmission filter is located is a plug. Remove the plug and behind it is a relief valve. Remove that and inspect it for anything that is caught in it that may be holding it open. You may have to remove that vertical filter and look up inside the filter housing to see the relief valve. You can also pry on the relief valve thru the top of that filter housing to help remove it.. It also could be a failed engine clutch that is the problem. Try the clutch pedal, and see if ity feels any different or if you hear any strange noises.
