'49 A update and another question
TractorDave
05-18-2005 17:15:30
third party image
I got the engine squared away and she's almost ready for testing. Tentative test day this weekend, Sat or Sun, depending on if my coil arrives by then. Hopefully if all goes well it is ready for paint! By the way check out that carburetor, Burrey carb did an outstanding job!
Now my question: My grandfather has a 720D with front weights on the frame, I wonder will the weights bolt on to the frame of my late A? I will probably just go measure the holes but thought someone here might already know the answer.
Thanks to all for the help on my rebuild!
Dave
F-I-T
05-19-2005 10:20:32
 Re: '49 A update and another question in reply to TractorDave, 05-18-2005 17:15:30
+++Now my question: My grandfather has a 720D with front weights on the frame, I wonder will the weights bolt on to the frame of my late A? I will probably just go measure the holes but thought someone here might already know the answer.+++
The front frame width of the tractors is the same, as cultivators mounted there with the same brackets. The frames only got wider back by the block, so the weights might indeed fit. Now the question is, do you want them on the front? That "A" will steer hard enough without more weight unless you plan on putting a bunch of weight on the back.
Frank
tractordave
05-19-2005 11:28:07
 Re: '49 A update and another question in reply to F-I-T, 05-19-2005 10:20:32
Good point Frank. I was just thinking the extra weight might help keep the front down when I go to the antique tractor pull, and I do not want to fab up those "tractor puller" weight brackets and all because they look dumb. The weights I speak of are John Deere weights that do bolt into the same area the culivators bolt up so they probably will fit. Now I wonder if the extra weight will be worth the harder steering, especially since I don't care if I win the pull, I just want to "go play" with my tractor!
Dave
F-I-T
05-19-2005 11:43:58
 Re: '49 A update and another question in reply to tractordave, 05-19-2005 11:28:07
Dave:
They might be worth the trouble of putting on and off from pull to pull, but I think you might get tired of steering with them on there. I know the first you do is get it running, and the second thing you do is put a spinner on the steering wheel!
HA!
Frank
tractordave
05-18-2005 17:18:06
third party image
tractordave
05-18-2005 17:16:58
third party image
RonMC
05-18-2005 21:43:49
 Re: '49 A update and another question in reply to tractordave, 05-18-2005 17:16:58
Beauty, Dave, I see you"re also going to hide a lot of nice work when you put the hood on ! I had the same feeling with my MC, but I know it"s there ! Ron
Stan - Florida
05-19-2005 05:02:15
 Re: '49 A update and another question in reply to RonMC, 05-18-2005 21:43:49
Ron,
And a dandy your MC is, along with your others!
Stan
