70D water everywhere but radiator
Pasbon
05-18-2005 08:00:03
My bubble was shattered, Had the 70d fueled,oiled, and new filters and was putting water in radiator to see if I could make a putt putt and smoke when water ran out of exhaust of engine and dipstick tube,whole engine full of water. Seems it was filling block as fast as I put it in top of radiator. Question is will a crack or bad head gasket flow that much water?probably pull head first unless there is something else to check first. HELP ? thanks
Marks2
05-19-2005 09:15:02
 Re: 70D water everywhere but radiator in reply to Pasbon, 05-18-2005 08:00:03
If you find it is cracked...I have a JD 730 head for sale (imroved version) F3511R. I emailed you.
Mark (937)313-2508
buickanddeere
05-18-2005 08:50:43
The 70D's were noted for cracking the original cylinder heads. There are two other part numbers for later improved heads. Both with larger intake valves. The best don't have brass inserts in the injector bosses.
F-I-T
05-18-2005 08:37:23
Since you now have water every where, I would do some diagnostics first.
I would drain the oil and leave the plug out. Also the filter. I would take the top cover off of the injector pump gallery so I could see what is going on in there, and take the valve cover off.
Then I would thread some pipe in the drain plug of the head so it exitted out to the side in to a tee arrangement. Put a plug in the and of the tee point down, and put some clear tubing in the tee standing up. Start adding water slowly until water starts running out of the crankcase drain area, or it runs out of the valve cover area, or it rises up and runs out of the injector pump gallery.
I think you'll be able to narrow down the possibilities before you tear it apart this way. Then again, it should be very obvious if it's passing water at a high rate.
THe block is blind ended, so fir it to pass water out to the crankcase would mean cracked to trough to the cylinder. The head is blind to the valve cover side, so for it to pass to the crankcase, it would have to be cracked on the valve cover side (my bet). If the head is cracked on the cylinder side, it wouldn't be able to pass water very fast and get it past the rings.
My guess, the head is broken at an exhaust valve area, the water is running down the oil return ports of the head filling the crankcase, and out the the exhaust valve area.
Frank
Blksmok
05-18-2005 08:27:57
Pasbon....when the blocks on 70D's crack they usually crack on the pulley side underneath the injection pump. Pull the cast iron pump cover off and check under the pumps for cracks and uneven surfaces. I'll bet you can fill the radiator and watch the water flow out of the cracks and down the push rod openings and into the crankcase.
old
05-18-2005 08:16:37
Yep a bad crack or bad head gasket will do just that if they are real bad. Also could be sorry to say this a cracked block.
