D Geek, Gee you already done shot down my list of usual suspects. When they are difficult to hand start but pull start n run fime, first things I suspect are low compression or a weak mag impulse spring. A squirt of oil in the cylinders might help (try it n see) if shes low on compression, but sounds like shes just been worked on so that shouldnt be the problem. If the mag impulse spring is weak the starting spark is weak, but a good blue spark as you desribed partly rules that out. See if the spark is still good n blue if you open the gap to 1/8 to 1/4 inch????? If not, the mags impuse spring may stil be a tad on the weak side. Try new plugs just in case. After a faled hand start attempt, are the plugs real wet (maybe youre over choking and flooding) or bone dry (not enough gas). Im not much of a D Man, but maybe after installing new plugs try different amounts of choke n throttle (depending on how plugs looked) and try to choke full just a cyliner over or two or until you get some gas vapor (NOT raw gas) out the open petcocks, then set the choke to half or a lil over n see what happens the next pull??? Those plugs can be finicky so try a frssh set and if the mags points are gray oxide coated clean/buff/polish them non abrasively (maybe a shop rag or a dollar bill), or if burned or pitted or blackened replace them. If the spark is still blue at 1/8 to 1/4 inch (otherwise maybe mag spring is weak) and you have new plugs and good compression PLUS CLEAN FRESH WATER FREE GAS then think its a matter of choking and starting methods, which the good D men can help ya with way better then I Good luck n God Bless, let us know John T
