730D Running odd with no load
Marty G
05-18-2005 03:02:56
Hope someone can help with this problem. My 730D runs great out in the field pulling plows and harrows but when I was driving the tractor home it seems to skip or miss fire on both cylinders with no load and there is a tiny sound coming out of the top of the motor. Putting the breaks on to put a load on the motor brings the motor back to good running sound. Dose It sounds like a governor problem? Thanks for any info.
msb
05-18-2005 21:28:44
 Re: 730D Running odd with no load in reply to Marty G, 05-18-2005 03:02:56
Those things were known to throw a part of a govenor weight on occasion especially if you did like I did when I owned one and kind of pushed the limit on governed speed like 1300-1350 RPM.Symptoms exacly as you describe.
buickanddeere
05-18-2005 08:52:06
Tired injectors spraying at too low pressure.
GPULLER
05-18-2005 08:02:44
The transfer pump pressure is to be 12 to 24 psi.
jddriver
05-18-2005 04:44:18
I would check fuel pump pressure at the pump on right side of govenor housing.I dont have the book in front of me but I think it is around 60 lbs but you need to check that and be sure.Steve
