A - JD Transmisson Bearings
K Black
05-17-2005 18:11:23
I have a 1936 A John Deere that I am needing transmission bearings for. They go inside the counter shaft idler gear. John Deere no longer offers these bearings. They are two roller cage bearings, one large and one small. Hyatt bearing made the bearings and races. I need a source to replace them. I have replaced the roller cone bearings on both the upper and lower shafts and the ball bearings as well. I have a lot of vibration espically in high range and some in low range. I hope to find replacement bearings to eliminate the noise and vibration. The vibration seems to be less under a load.
Henry J
05-17-2005 19:56:39
 Re: A - JD Transmisson Bearings in reply to K Black, 05-17-2005 18:11:23
K
I have been able in the past to goto a bearing specialty place like Motion Industries that specializes in bearings - or a good auto parts store, and they can cross out JD bearings to whatever they sell.
In my experience JD did not have their special/peculiar part numbers stamped on the bearings and races like they did the seals.
