JD 214
charle1979
05-17-2005 13:01:11
I recently bought a 214 lawn tractor. When I engage the manual clutch that runs the deck it kills the engine I checked the safety switch under the seat that isn�t the problem. Any have an idea Thanks
F-I-T
05-17-2005 13:13:52
 Re: JD 214 in reply to charle1979, 05-17-2005 13:01:11
Charlie:
Does your 214 have the manual PTO lever (early 214) on the dahs or the electrical clutch (later 214)using the switch on the dash?
I wasn't sure from your wording. I used to have an early one and as I recall, the PTO circuit was only the seat safety switch, and the cranking circuit was the gear shift in neutral position switch as well as PTO off switch.
If it's an electrical clutch type, there might be more to it.
Frank
charlie1979
05-17-2005 13:48:27
 Re: JD 214 in reply to F-I-T, 05-17-2005 13:13:52
It is an early modal with the manual lever pto. there is an electric lift for the deck on it and that is not working and is in the up position so i don't know if maby that might be the problem also. do you think there is a saftey switch on the deck?
F-I-T
05-17-2005 15:04:58
 Re: JD 214 in reply to charlie1979, 05-17-2005 13:48:27
Charlie:
Not that I remember. Mine had the electric lift as well. You might try removing the power to the deck lift just to make sure, but I doubt it. You should have blown some fuses by now if that were an issue. As I recall, that deck should turn whether the lift is full up or down, as the pto could be turning a tiller, a snow blower, or a deck just as well.
Have you taken the belt off of the PTO clutch to make sure it's electrical and not the PTO clutch froze up?
Frank
