45W loaders
Jake 123
05-17-2005 10:43:28
45W Loader has original cylinders. Only had a pressure hose to the back end port, and a vent plug on the front. I have plumbed into the return line with the front vent port with new hoses, I read about that on here before for increased oil capacity. Added new oil, with the loader down on the ground, until the oil runs out the drain cock. Unfortunately the loader runs poorly. Cavitations, and leaks from the seals at the front of the cylinder seals where it never did before.
On the cavitations with all of that hose and cylinder needs, am I under filling the reservoir? How do you fill the reservoir, do you fill it as best you can intially loader down, lift the loader (expand the capacity needs) and add more?
On the leak that wasnt before there, maybe a back check valve inline? or rebuild the cylinders?
Mike M
05-17-2005 10:53:45
 Re: 45W loaders in reply to Jake 123, 05-17-2005 10:43:28
What model tractor are you putting it on ???Not all models need the extra hoses to the front. It is leaking now because you have oil on that side you did not have before.Worn seals,pitted chrome will all need to be replaced to stop it.
Jake 123
05-17-2005 10:56:45
 Re: 45W loaders in reply to Mike M, 05-17-2005 10:53:45
Its a 60
Mike M
05-17-2005 11:09:54
 Re: 45W loaders in reply to Jake 123, 05-17-2005 10:56:45
Yes you will need the hoses hooked to the front. Even with leaks(unless major) it should work ,but it does take some time to cycle the air out.
onefarmer
05-17-2005 11:27:17
 Re: 45W loaders in reply to Mike M, 05-17-2005 11:09:54
Recheck the oil level as it will take some to fill the front previously empty side.
