3020 gas problem
mgb
05-17-2005 09:46:06
What carburator replaces the Marvel Schebler that came on my '67 3020 gas? Two kits and three cleanings later and it still floods to death. The tractor is virtually useless. Even the old JD mechanics don't won't to touch it. They just shake their heads and say, "Better buy you a diesel." I have heard one or two good stories about these gas tractors but I've lost count of the bad stories. I'm serious folks. These carbs were and are junk! And I'm not getting any use from this tractor.
3010 Ken
05-18-2005 04:33:41
 Re: 3020 gas problem in reply to mgb, 05-17-2005 09:46:06
Morning,Mr.Mgb;Had an M.S. carb on a Ford 600 tractor. That ting acted much the way you described in your post.I replaced the carb with a zenith off of a wisconsin v-4 engine and that was it,no more problems! Kenny
mgb
05-17-2005 13:00:59
 Re: 3020 gas problem update!!!! in reply to mgb, 05-17-2005 09:46:06
Thanks for the info. I had heard that Zenith was the answer. I forgot to explain that the flooding problem is not in cranking but after the tractor is running it spits and pops, runs rough and puts up a long column of black smoke at any RPM. It's running way to rich but no amount of adjustment helps. I had it running fairly good when I got it a few months ago but then it started to flood out at over 1500 rpm and since then it has been down hill. One more thing. If I fill the tank with gas to a level above the carb then gas poors out ever opening in the carb until I either shut it off under the tank or the level drains below the carb. Yes. It has a new needle and seat. It didn't help.
Gerald J.
05-17-2005 18:58:54
 Re: 3020 gas problem update!!!! in reply to mgb, 05-17-2005 13:00:59
If it floods like that, then the needle and seat isn't sealing. Probably because the float isn't floating, or the gasket for the seat is missing, though there could be a crack in the inlet part of the carburetor. The needle and seat should close off all the air you can blow through the inlet fitting (with your mouth) with very little pressure. The float should not slosh when you take it out and shake it. It could be the float is bent and dragging on the side of the float bowl or isn't set right, likely the float is full of gasoline.
Gerald J.
Jon (IN)
05-17-2005 10:39:41
I replace the MS carb on my 1966 Oliver 1850 with the Zenith. I was in exactly the same boat, rebuilt it a couple of times and had some experienced mechanics go through it with no resolution. I ended up springing about $425 for a new Zenith. If she doesn't fire up right away in the winter (due to slow cranking) it can still flood, but when it's above freezing she fires right up.
Also, make sure your ignition is in good shape. A new coil helped mine in starting, which kept her from flooding out.
Jon
Mike M
05-17-2005 10:38:42
Go with the Zenith. I have a 4020 gas and the best thing I ever did was to get rid of that aluminum box p-o-s carb. I got lucky and found a rebuildable one cheap with an adjustable load jet.
Glen in TX
05-17-2005 10:36:43
Some of the JD gas swathers used same carb and we replaced one with a new Zenith from JD and never looked back. You can probably get one for some less from the tractor supply places. The accelerator pump got worn in those old ones and they weren't that good to start with.
Gerald J.
05-17-2005 10:13:29
The M-S carburetor used on the 3020 and 4020 has a poor reputation. Its so hard to adjust that there's a late 60's vintage Deere Service Bulletin that suggests replacing it with the alternate Zenith carburetor.
The M-S carburetor uses a large vacuum operated diaphragm (under that rectangular cover) for the acceleration pump. A split in that diaphragm surely feeds excess fuel to the intake manifold that supplied the vacuum. The diaphragm doesn't seem to be in most rebuild kits.
The Zenith carburetor uses a brass acceleration pump and is easier to adjust.
Its likely the Zenith carburetor to fit is still available from JD. I'm sure that YT, value built (SP), and Shoup (www.shoupparts.com) carry it for about $500.
Gerald J.
