Brakes 620/720
onefarmer
05-17-2005 09:01:02
For someone in the know. Is the brake assembly on a 720 the same as a 620. The brakes are worn out and the pedal no longer returns on its own on my 620. I found a 720 brake that is in much better shape but will it fit? Thanks in advance.
onefarmer
05-18-2005 06:41:12
 Re: Brakes 620/720 in reply to onefarmer, 05-17-2005 09:01:02
Thanks for the replies! I know it would/will be an easy fix. I just saw a possible easier fix. Looks like I will be getting some shop time next winter. My father bought this tractor new when he was still in high school and it is the first tractor I remember riding on. Or driving for that matter. I aquired it after my father passed on last Jan and it has a lot of memories. I was suprised at how fast I took to it again. I haven't used it in years. My hands remember exactly where the clutch and shifter are.
tsmith1499
05-17-2005 20:23:00
Your pedal may not be returning because the spring inside the brake drun that keeps the shoes together may be broken. A friend of mine had the same problem. Ended up being a broken spring.
CLW
05-17-2005 20:16:12
I just checked my parts CD and it shows the shoes, housing, drum and shaft to all be a different part number on the two tractors. I didn't look any farther. Don't look like it will work. But like was said before they are not hard to rebuild. I did it on my 630 and I am a long way from being a mechanic.
CLW
donwisc
05-17-2005 12:52:20
Do not believe the 720 brake will fit BUT since you will have to take the brakes off any way, take one apart and see what it will take to rebuild.
Generally all you have to do is remove , cleanup and relube the adjuster pins, cam pin and brake pedal shaft and you are as good as new with new brake shoes. There should be a lot of info in the archives as this is not a new question.
Good luck
