DTLX Newbie
Gary U in CA
05-17-2005 07:05:39
Hello everyone!
Well, I've transferred into new territory (well at least for me). I�m making my first attempts adjusting a JD720 gas tractor. All my knowledge to date has been with 70 and 820 diesel.
Currently, I�ve removed and fully cleaned the carb and oil pressure switch assembly. The tank is clean and an inline filter has been installed. The engine is having a hard time getting fuel�.it only runs with the choke half on.
I was considering bypassing the oil pressure switch; I�d like your thoughts before I go further.
Also, what are your best practices for successfully setting up carburetion?
Thanks!
Gary
F-I-T
05-17-2005 20:47:20
 Re: DTLX Newbie in reply to Gary U in CA, 05-17-2005 07:05:39
Gary:
I'm still knocking around Pasadena. We need to meet up some time and have dinner or something. Been a long time since I monkeyed with a two-barrel Marvel-Schebler, but I'm always game, especially if it isn't working right now!
If you take the bowl off or open the drain cock, how is your fuel flow? As always, you need lots of good flow to make sure the bowl level stays consistent so that they idle nice and meter well. If the fuel flow is skimpy, work backwards and fix that first. Could be the oil pressure controlled valve, or as was said, could be the screen in the top of the sediment bowl. Again, you say the tank is clean, but are you sure there isn't a grain of wheat in the very top of the fuel opening to the sediment bowl? (they ask why he would mention a grain of wheat like he might have found such a thing one time in the past.....).
Watch those in-line fuel filters....some of them don't flow well without the help of a fuel pump, but I'm sure you already know that.
Give me a call sometime!
Frank
Cell 850-322-415
Gary U in CA
05-18-2005 18:40:02
 Re: DTLX Newbie in reply to F-I-T, 05-17-2005 20:47:20
Frank:
I'll try giving you a call tomorrow. I'd really enjoy a dinner together. Some good thoughts on the carb, would be happy have you head out to hook up.
Talk to you tomorrow!
Gary
John in Md.
05-17-2005 15:25:18
Try replacing the screen in the top of the glass fuel bowl, sometimes they get gummed up. And watch the fuel bowl while the tractor is running to see if you are getting air in top of glass could be dirt in line or tank. Rebuilt the carb on a 530 three times before I started looking for other problems.
Gary U in CA
05-18-2005 18:42:41
 Re: DTLX Newbie in reply to John in Md., 05-17-2005 15:25:18
John,
Thank you for responding. The screen was actually removed to eliminate any issue with it. I will take a look for the flow, great idea.
Gary
bent
05-17-2005 08:04:18
Gary, when you say the carb is "fully cleaned" does this mean you have the idle passages clear? These can be a real bear. If you remove the idle needles from each side can you get air from the bowl to come out of the idle passages? If not, it wont run right as this is where the fuel comes from until the tractor is under load. You have to choke it to get it to suck fuel from wherever so it can run. My 630 does this once in a while and I have to take the carb off and get the passages clear. I like to use high pressure cans of carb cleaner with tubes then I can stick the tube right into the idle passage, then clean out with air.
Good luck.
bent
Gary U in CA
05-18-2005 18:47:19
 Re: DTLX Newbie in reply to bent, 05-17-2005 08:04:18
Thanks for the response.
I did just as you suggested, good to know that it was a good approach. The passages appeared to be clear. I believe I am going to circle around and try to identify any low flow causes. Please pass along any other suggestions you might have.
Thanks,
Gary
