Help on 4010 hyd hookup of post driver
gwece
05-17-2005 06:44:15
third party image
I just got an old Shaver HD8 3pt hitch post driver and put on my 4010. I just hooked the hoses to my hyd remote and then tied the dash hydraulic lever "open" with a couple of tarp straps. The driving ram will raise and lower pretty fast but does not freefall like it should. I contacted Shaver by email and they told me "YOU NEED TO RUN YOUR RETURN HOSE BACK TO THE RESERVOIR OF THE TRACTOR. YOU ARE CONSTRICTING THE "DUMP" WHICH STOPS THE FREE FALL." Can someone out there tell me the proper way to hook this thing up? Thanks
thurlow
05-17-2005 07:35:00
 Re: Help on 4010 hyd hookup of post driver in reply to gwece, 05-17-2005 06:44:15
Phil is correct; I have a front-mounted Shaver which looks very similiar to yours, except the return line is about 2 inches in diameter. The tractor fill cap is pipe thread; remove it and dump the oil there. Mine has an elbow and pipe union for secure connection with no splash.....
gwece
05-17-2005 07:46:26
 Re: Help on 4010 hyd hookup of post driver in reply to thurlow, 05-17-2005 07:35:00
thurlow: Pardon my dumbness on this, but do you just plug in your hyd supply hose to one side of the remote? Do you still have to strap the dash hydraulic lever in the open position? Thanks!
thurlow
05-17-2005 08:40:19
 Re: Help on 4010 hyd hookup of post driver in reply to gwece, 05-17-2005 07:46:26
Yep, you've got pressure in both outlets; just figure out which one will give you pressure to the correct side of your driver valve and tie lever open to give pressure to that side.....
Phil/PA
05-17-2005 07:16:04
The post driver I use (not a Shaver but they should be similar) has a return hydraulic line that is about twice the diameter of the inlet line. The hydraulic fill cap is removed from the tractor and the return line is inserted in there, not on the other other side of the remote. This allows the driver to quickly remove all the fluid. Hopefully I explained it properly but if you want me to take a picture let me know, the driver is currently hooked to my 4020.
gwece
05-17-2005 07:40:56
 Re: Help on 4010 hyd hookup of post driver in reply to Phil/PA, 05-17-2005 07:16:04
Phil: Pic would be great! Also tell me about your post driver. Does it do a good job? My email is [email protected]
Thanks!
Mike M
05-17-2005 06:48:50
That 4010 uses closed center hyd.system is the valve you have made for this ? or is it an open center valve ?
