Best loader for a 4010 gas?
PUTTER
05-16-2005 20:40:58
I've got a 4010 gas with 34inch rears and 1 remote. Which loader did John Deere recommend for this tractor. Will be using it to load round bales and move snow if I can find one at a fair price. Thanks PUTTER
61-4010
05-28-2005 14:12:14
 Re: Best loader for a 4010 gas? in reply to PUTTER, 05-16-2005 20:40:58
I just purchased a model 58 for my 4010 diesel. Works terrific.
txgrn
05-18-2005 06:39:03
Once I bought a very used JD 152 for a 4020 for $3600. Had to redo all hyd cyl and repl hoses. It had 4 mounting points for the bucket and one person could not connect it. Also it was bolted onto the tractor so it was a chore to remove.
Last year I went to Koyker co. in S. Dakota (on the www) and bought a Model 310 for my now owned 4010. It cost $3600 New including shipping and the hay spike; bucket was another $500 if you wanted one or deduct $400 if you didn't want the spike. It also has quick mount to the tractor (with storage stand for quick reconnection) and the implement connection is merely 2 spring loaded 1" pins. Can install/remove implement in about 10 sec alone.
Mark
billde
05-17-2005 05:27:42
148 Deere loader would be the best. Expensive but a well built loader that will take anything you give it.
Gerald J.
05-16-2005 20:56:40
48 or 148.
You may need to find a loader with its own valve, then tap the pressure at the elbow just in front of the brake pedals with return to the hydraulic filter housing on the left side of the transmisssion. You will want a flow restrictor valve in that line to the loader so its easier to control.
Gerald J.
