FIT
Russell G Mont
05-16-2005 15:54:08
Frank I changed the axle seals on a 720 and I took it out for a ride saturday and it doesnt want to shift easily. It doesn"t want to shift at all to the right side of the quadrant and it doesnt want to go into 4th very well either. It was shifting ok before taking the bull gears out. Could I have installed the bull gears incorrectly or something else. Thanks for the help.
F-I-T
05-16-2005 16:46:00
 Re: FIT in reply to Russell G Montgomery, 05-16-2005 15:54:08
Russell:
I can't really see how the bullgear installation would affect the sliding gears, which are separated from teh bulls by the differential and the intermediate shafts. Could it be just a cruel coincidence that you have a quadrant/shifter problemm occurring at the same time?
Did you do both sides? Didi you return the bull gears to their original sides, and do you know if you put the same sides toward the outside?
I'm kind of grasping at straws here.
Frank
05-16-2005 19:11:09
 Re: FIT in reply to F-I-T, 05-16-2005 16:46:00
Frank I put the bullgears in with the best way I can describe it is the gearing of the axle had made impessions on the backside of the nut. wheras the other side of the bull gear had impressions of the brass shim on it. The inside of the bullgear had gearing on the inside and the otherside had been machined flat. The flat is towards the transmission case.. I had everything marked but one gear had been flipped over and instructions did not match. I tried it the other way but it did not seem right. Thanks again for the help.
