JD 1020 help
Tufunuf
02-23-2004 15:05:31
I have what a JD 1020 gas that has a bad (grinding) water pump. I took the pump off thinking I could replace the bearings or whatever is grinding. But, it looks like the unit is factory sealed. Is there any place to get this pump rebuilt, or is there a way to take it apart and replace the inner works? I can not find a number on the outside of the pump to reference.
The JD place said they would sell me one for $400. The tractor ain't worth $400! Just kidding. But, that sounds steep for a water pump. Your help would be appreciated.
Thanks,
Tuf
Steve
02-24-2004 08:57:45
 Re: JD 1020 help in reply to Tufunuf, 02-23-2004 15:05:31
third party image
We have reman pumps available for the gas or diesel. Priced under $100 plus core. You can order online by going to our website and clicking on the A&I link. There you can search by make and model. If you have any questions feel free to contact us.
Karen
02-24-2004 03:52:27
I know where to get a rebuild kit for under $100 and impeller if you want to do it yourself but you should think about. They are not always easy to press and like david val said
Karen
02-24-2004 03:37:40
I know where to get rebuild under $100. Email me.
Bob
02-23-2004 17:47:19
Bearing JD 9257... $17.99 at Deere
Seal kit AR 101549... $8.50 at Deere
Misc. gaskets also needed, as well as a shop press, and a little patience.
Tuf
02-23-2004 18:19:48
 Re: Re: JD 1020 help in reply to Bob, 02-23-2004 17:47:19
Thanks for all the help.
Tuf
david val
02-23-2004 23:46:28
 Re: Re: Re: JD 1020 help in reply to Tuf, 02-23-2004 18:19:48
i never encountered a gas water pump but i think it's pretty similar to diesel.
if you have no experience with these pumps, i would be very careful working on one with a press. you can easily brake the housing or the pulley in the process and end up paying that $400... best is to get a manual and follow the instructions or have someone experienced do the job. if you buy the parts in advance, get also the impeller and the gaskets.
david
Tufunuf
02-24-2004 16:01:43
 Re: Re: Re: Re: JD 1020 help in reply to david val, 02-23-2004 23:46:28
Thanks for all the good information and help!
I went ahead and bit the bullet and took it in to the JD dealer to have it rebuilt. I was a little nervous about cracking the housing, etc.
Thanks again,
Tuf
Brokenwrench
02-23-2004 15:18:18
Ask your dealer to rebuild it. They should be able to do it for $125-150 parts and labor. You can buy the kit to do it from Deere,and if you have acces to a press and take your time,can do it yourself in about 20 minutes.
Tufunuf
02-23-2004 15:33:35
 Re: Re: JD 1020 help in reply to Brokenwrench, 02-23-2004 15:18:18
Brokenwrench,
I guess it presses from the inside out towards the fan. That would be right wouldn't it? Probably a dumb question, but I don't have it at the house to look at.
But, you think the JD place will have the parts to rebuild it with. If so I can take it to a press and do it myself. Does the JD place need a serial number off the water pump, or can I just carry it in? I couldn't find a number on it.
Thanks very much,
Tuf
