110 mower
need help with
05-16-2005 08:21:36
I have a old JD 110 that won"t start I fuel and spark but it will not start. What should I try next. Thanks
mowr
05-17-2005 05:36:49
 Re: 110 mower in reply to need help with old mower, 05-16-2005 08:21:36
Has it been sitting? (stale gas, low compression from dry cylinder walls, bad spark plug?). Has it been repaired since it last ran? (cam timing off?). Or was it running today, gassed up and wouldn't restart? (water in gas, stale gas?). Just some thoughts.
help with mower
05-17-2005 08:17:34
 Re: 110 mower in reply to mowr, 05-17-2005 05:36:49
it has been sitting for about a year, put a new plug in and when I parked it I put stabil in the gas. thanks
mowr
05-17-2005 18:24:43
 Re: 110 mower in reply to help with mower, 05-17-2005 08:17:34
I think a year is pretty long for gas, even with stabil. Anyway my suggestion would be to first put about a teaspoon of motor oil in the spark plug hole, let it sit for a minute, then turn engine over slowly to coat the cylinder wall (this to make sure the rings have as good a seal as possible with the cylinder to build compression). Hold finger or thumb over the spark plug hole and turn engine over to see if you have compression. If not, a valve has probably stuck in the guide from sitting. If yes, replace plug and try to start the engine. Let us know your progress.
