620 stuck clutch
jdjack
05-16-2005 08:07:45
Bought a 620 that didn't run and clutch cover was missing. (Had been sitting for a few years) Got carb rebuilt, pulled it to start and clutch is always engaged. Removed clutch and and cleaned dog bolts are clean and free. Put back together and same thing. Fork is in correct spot. Removed clutch again. Installed one disk and installed clutch driver, still free, tightened bolt on driver. When bolt is just about tight it locks up.
Clutch driver sticks out from crankshaft. Cleaned all rust still locking up. Clutch driver doesn't seem loose. Anybody have any ideas?
Thanks for any help
Mike M
05-17-2005 10:50:24
 Re: 620 stuck clutch in reply to jdjack, 05-16-2005 08:07:45
I would double check the casting number on your driver and make sure it is for a 620. A few more thoughts Does the your 620 have any adjustments on the fork bronze yoke ? Some models have some adjustments inside of there.Also the fiber thrust washer inside the crank case to control the crank end play could be gone allowing the crank to go too far to the left ? This might tighten up things on the right side.
Merle Hoppenworth
05-16-2005 10:38:50
If the driver is still farther out than the crank as the bolt is getting tight it sounds like you have a clutch lining that is too thick (if it is a new one) or if it is an old one it could be swelled up and too thick. Could it be that there is 2 clutch linings behind the driver? What ever there isn't the clearance there that is needed.
Had this once on a 720 puting in new clutches. Picked out the best old lining, put it behind, and used all new ones on the outside. worked fine.
