1010 GENERATOR
gasmith
05-16-2005 07:35:56
My manual indicates that I have a positively grounded electrical circuit however the negative battery terminal was connected to ground. I have had trouble with dead batteries and the system not charging. I did have the generator tested and it looked good. Thought maybe my problem was due to the grounding. I simply reversed the battery leads and tried to re-polarize the regulator per the manual (really wasn't sure which two leads to touch with a wire) and I fried my generator after starting my tractor. Was there something else I needed to do - change other wires? What is correct way to re-polarize the regulator? Not sure what to do now.
John T
05-17-2005 07:35:55
 Re: 1010 GENERATOR in reply to gasmith, 05-16-2005 07:35:56
Gas, its the Generator you have to Polarize, NOT the Voltage Regulator. First dead ground the Gens Field post to frame/case, then MOMENTARILY flash jump a wire from the VR"s BAT terminal over to its ARM terminal and you ought to get a spark.
John T
jdemaris
05-16-2005 20:04:35
The generator can be polarized to work either way, but most voltage regulators will not. Usually the regulator is marked POS or NEG ground, and which ever way it's marked is the only way it will work. If it is marked N/P than it's a convertible regulator - but they are not common.
