435 front end wander
Dan J
05-15-2005 16:26:41
Just bought a 435 today and it seems to run fine but shakes badly in high gear down the road. Dosn't look like tie rod ends. Where should I start looking? Thanks, Dan
txgrn
05-16-2005 05:11:29
 Re: 435 front end wander in reply to Dan J, 05-15-2005 16:26:41
I bought a european built Ford that had 750x18 fronts on a 52 hp tractor mind you. Huge tires. Wandered, not wobbled down the road. Replaced drag links and tie rod ends which corrected a lot but the spindles were worn real good. Not going to replace them.
By accident, I put about 200# on the front so that I could move large hay bales and guess what. That added weight settled the front down and she hardly drifts now.
Might work for you.
Mark
buickanddeere
05-15-2005 17:27:56
Both of my 435 were awful wobblers even with new tie rod ends, steering shaft U-Joints etc. It wasn't until jacking the front end up and ajusting that set screw on the top of the steering bow. Cranked her down so tight that the steering would bind in places even with the wheels off the floor. Synthetic lube in there too so the set screw could go another couple of thou tighter and still be able to steer through the binding spots. Running the front tires with air pressure so low the sidewalls bulge some, help reduce wobble. Most of the Dubuques were wobblers, nature of the beast.
Henry J
05-15-2005 17:15:49
Dan
Pull the sheet metal (aaarg).
Then jack the fron end up so that the front axel and wheels are hanging free.
You will probably find several places with slop. take the slop out of the steering wheel from one end to the other and watch what moves and doesn't.
In this position you can move the front wheels back and forth to check for front end slop.
If you are lucky the worm gear in the top 90 degree box is not ground up.
there will surely be one coupler in the front column that may be wollered out also.
jCarroll
05-17-2005 18:35:52
 Re: 435 front end wander in reply to Henry J, 05-15-2005 17:15:49
Ans don't forget the easy stuff.
Check the toe-in. I run my Dubuques with 1/2 to 5/8" toe-in.
