Gloom and Doom
txgrn
05-15-2005 06:19:51
With idiot lights when the engine bearings start wearing you can't verify it by fluctuations in oil pressure on a hot engine at idle.
With the new fancy thing-a-mabobs with a gauge you can.
Yuck!
So the question is, how bad is the wear to be able to see the oil pressure fluctuating....Don't want to hear the answer. Ha.
Mark
R. John Johnson
05-15-2005 16:24:18
 Re: Gloom and Doom in reply to txgrn, 05-15-2005 06:19:51
Mark
Which one of the herd is sick?
John
txgrn
05-16-2005 05:25:50
 Re: Gloom and Doom in reply to R. John Johnson, 05-15-2005 16:24:18
Hi R. John,
Wouldn't you know, it's the high $ darling !@#$%^&*()_+ I just added to the fleet. Yucko.
Only saw oil pressure wobble like that one time on an engine before and it was at a scrap yard. A highly worn out OTR truck tractor was there and I cranked it up and guess what I saw.
It's either mains or rod bearings; as diesels wear the bottoms out first (as I'm sure you know). Doesn't really matter as when I go in, both will be new. Find it odd that it would be a problem at 3900 hours. The rest of the tractor shows very little wear in the wear spots indicating OEM equip still there and little use, and supports the hours.
Course it might be something else. Now that I did the dual 12v thing on the batteries and it has warmed up outside, she kicks off in a second so the rest of the engine is in great shape. Responds to throttle settings instantly, runs smooth and no funny noises. Just doesn't make sense to have the bottom worn out and nothing else indicating wear.
Couple of oily, sloppy days on my back and $1k ought to fix her up. Just wonder how long I have before I have to do it. Ugh! Course, maybe if I just play lazy (goodie) I'll stumble across something insignificant causing it.
It has all new fluids, filters, and all that. This was the first time I really smoked the tires since buying it in Jan. It may be that it hasn't been worked and there is some sludge in the oil sending chain, and all I have to do is work it out....now I like that. But the problem is that cold, it's steady and it jittered at low rpms hot...We know the rest of that story.
Thanks,
Mark
thurlow
05-16-2005 07:47:31
 Re: Gloom and Doom in reply to txgrn, 05-16-2005 05:25:50
You said "no funny noises", so it's probably not this; had a 4020.....still got it, actually.....had a little more noise in the bottom than I liked; pulled the oil pan; bolts in EVERY rod bearing cap could be turned with your fingers; this was at about 8000 hrs; don't recall that it affected the oil pressure light, though.....
MSM
05-15-2005 11:46:49
Depends about what kind of vehicle/tractor you are talking about.Some oil senders light the light at 3#,others at 10-12#. Easiest check is to remove the sender and install a known good numbered guage. Could be as simple as a bad sender,or an oil pressure relief valve needing to be cleaned or reset(tractor),fuel dilution from a stuck float or bad transfer pump or clogged oil filter.
txgrn
05-16-2005 05:30:15
 Re: Gloom and Doom in reply to MSM, 05-15-2005 11:46:49
I was reading my Ford manual the other day and it had the spec for the oil pressure light.
After reading that, I quit worrying about oil thinning out on a hot engine and oil pressure dropping down to 20ish, at idle, on farm machinery.
When I think of the millions of engines running around the world with nothing but an idiot light which says that teen oil pressur at idle on a hot day is ok, I got off my high viscosity oil soap box..... ..well sorta. I just quit worrying about "seasoned" tractor engines oil pressure. Ha. Still use my 15w-40 + syn blend however.
Thanks,
Mark
