430 baler problems
cracker head
05-14-2005 15:44:31
Neighbor of mine is having a problem with his baler . seems that the baler will not make the same size bale each time .It will make a bale app. 3 feet in diameter then start tying itself out . maybe the next one will be the right size at 5-6 feet which is the size he is trying to make then it may make 2-3 in a row that is 3 feet in diameter then back to the correct size. He changed the filter on the baler thinking it was maybe trash had gotten into the tying system but still has the same problem. any sugestions from the baler gurus.
HA in Oh
05-16-2005 02:06:07
 Re: 430 baler problems in reply to cracker head, 05-14-2005 15:44:31
The tieing linkage is not latching in home position. After dumping a bale and closing the gate make sure it has latch in home position. The linkage may just need oiled up. Mine did the same when I first got it, a little oil was all it needed. Good luck.
Mike Becker
05-15-2005 11:24:58
My experience says to REPLACE the v-belt running the hydraulic oil pump for the twine arm. It get longer with age and use and does not kick the arm hard enough to get it to the loaded position to make a full size bale. We had the same problem years ago and replace the v belt with a new JD replacement and the problem went away.
TLB337
05-15-2005 10:07:19
GPOWER IS CORRECT ALONG WITH CHECKING THE SPRINGS THERE IS A ROLL PIN IN THE LATCH LINKAGE THAT Y NEED TO CHECK FOR WEAR OR BREAKAGE WHEN THIS HAPPENS THE LATCH WILL NOT ENGAGE COMPLETELY THIS IS USUALLY THE PROBLEM AND FOR TIM THE 430 & 435 ARE FOR THE MOST PART THE SAME
Tim A.
05-14-2005 20:39:25
My 435 manual says: 1) Pump drive latch does not relatch--Solution: a. Make sure belt tension arm is returning all the way to the start position when closing gate (see also installing orifice in tractors with low hydraulic flow), b. V-belt tension bellcrank spring is missing, c. Check twine trip rod for proper adjustment, d. Mud build-up on rollers(???), e. Trip rope tied too short 2) Bale size link does not telescope freely--Solution: Find cause of binding and correct 3) Tractor tire trips rope--check for proper rope routing.
Not sure how close your 430 is to the 435...but hope this helps.
Tim A.
Gpower
05-14-2005 20:08:15
Check the 5 springs on the tying system. Use only JD srpings. What is happening is that the latch that holds the tying system in place until it is suppossed to pop open, is coming open too soon, or it is not latching at all once the gate is closed. Also check the linkage on that side, make sure nothing is bent nor mis-aligned.
All else fails, read the operators manual....very good info in there on these types of problems.
GP
