'49 A valve stuck HELP!!
tractorDave
05-14-2005 14:41:52
Alright guys here we go AGAIN!
I installed the head and rocker assy. which had NO signs of rust and now my right side intake and exhaust valves are both stuck open. They are stuck in the fully open position with the springs compressed. I tried working them free but they are stuck good. I filled the cylinder up with oil/diesel/PB Blaster and installed an old plug and turned the flywheel just enough so I could see liquid in the exhaust and intake ports.
Here is the question HOW CAN I UNSTICK THESE VALVES AAARRRRRGGGGHHHH!!!!!
Should I just go ahead and order ANOTHER new head gasket and tear the head off again?? Can I get the head gasket from NAPA?
Thanks again for all your help.
Dave
Ben.So.Tex
05-16-2005 04:12:42
 Re: '49 A valve stuck HELP!! in reply to tractorDave, 05-14-2005 14:41:52
I had this happen on an A and a 60, I oil them and tappped on them and grab the stem of the valve with a pair of channel lock pliers and twisted them alittle and they came loose. still working today. Good luck Ben.
tractordave
05-17-2005 10:20:49
 Re: '49 A valve stuck HELP!! in reply to Ben.So.Tex, 05-16-2005 04:12:42
Thanks for the tips everyone. The vise grips did the trick!
Dave
Dave NE IA
05-14-2005 20:57:14
Before you tear it down try spraying starting fluid on the stems. Believe it or not it will clean up carbon extreemly fast. Spray it, tap it then spray again. The time someone showed me this trick, it took less than 30 seconds and what we figured had to be a bent valve freed up. It sure is worth a try. Good luck Dave NE IA
old
05-14-2005 16:39:45
Just something to try before you take it apart again. Fill that cylinder with tranny fluid and make sure you have the engine turned so there is not rocker arm holding the valve open. Tap on each valve carefully and they may just pop closed for you, tapping works the tranny fluid in some and also will put more preassure on them. I'd also puor some tranny fluid on the spring side of the valve.
