4430 Power Shift
Flywheel
05-13-2005 19:53:51
If I cut out the plate where the gear shift goes thru for reverse gears on a 4430 Power shift can I get 5th and 6th reverse?
Gerald J.
05-14-2005 10:58:17
 Re: 4430 Power Shift in reply to Flywheel, 05-13-2005 19:53:51
4010 had three ranges of reverse. They locked the high speed one out of the 4020 because the gears couldn't take the torque and broke too often. That likely would be the result in those ranges in the 4430 too.
Gerald J.
donmyeil
05-14-2005 10:09:49
all eight gears would be there however i cant remember what stpos the lever. seems like the shift arms on the valve box hit each other at the 4 reverse point. you could unhook rods to see if you could do this down on the shift valve. CAUTION!! THIS WOULD BE DANGEROUS AS IT WOULD BE TOO FAST TO BE SAFE!!! NOT RECOMENDED!!
