John, this is kind of a broad wide open topic, the first thing you gotta do is try n determine if its a an ignition or a fuel problem. 1) IGNITION I would remove the coil wire from the distributor cap (leave coil end inside coil) and have that bare end to within 1/8 inch from tractor or engine steel, turn her on and crank her over and see if a spark jumps that gap. If so, (replace the coil wire into cap) I would remove the plugs and have their wires attached but sides grounded and again turn her on n crnak her over n see if both plugs are firing. If the coil wire fired but NOT the plugs, it a cap or rotor or plug wire or a plug problem. If the coil wire is not firing I would remove the cap and check the points gap on high cam and clean/buff/polish the points surfaces which may well be the cause of no fire. If she still dont fire after a points cleaning post back for more troubleshooting. Often for long periods of setting the points will oxide over and need cleaned or replaced. IF IN DOUBT I WOULD TRY NEW PLUGS AND CLEANED OR BETTER YET NEW POINTS AND GAPPED CORRECT 2) FUEL You gotta have fresh clean water free gas gettign to and filling the carb bowl and the carbs needle n seat n float assembly all working. Is there a drain cock or plug in the carbs bottom??? (not familiar with 40 carbs, sorry) If so remove it and insure clean gas flows out. If not insure the sediment bowl assembly or any other types of shut off vlaves are clean n fre cuz you gotta get gas to the carbs bowl. When cranking and if choking the carb are you getting any vapor or smoke out the stack??? If not I wonder if shes gettign gas. If you remove the plugs are they wet with gas (maybe shes flooded) or bone dry (no gas gettign to cylinders) SUMMARY You gotta have fuel n compression n spark to run. Likely suspects after long idle periods are points oxide coated (clean or replace),,,,, ,,,,, ,,plugs fouled (replace n try new ones),,,,, ,,,,water or stale gas,,,,, ,,,,flush n clean n refill with fresh gas,,,,, ,,,,carbs needle n seat or float not working (clean out with gumout maybe). Let us know John T
