JD 410 round baler
JOA
05-13-2005 06:20:36
Looking at a 410 baler for $3500, is this a good baler and is the price good.
Thanks for any info.
Mike Becker
05-15-2005 11:21:43
 Re: JD 410 round baler in reply to JOA, 05-13-2005 06:20:36
Take a close look at those bottom belts. JD put them in endless and you have to dismantle the baler to replace them. Aftermarket spliced belts work if you can get them. They do not last as long. 430 and 435 are open throut and a lot better baler. Monitor is a plus for the neck mussels. I have used a 410, 430, 466 and 467. I like JD balers.
TLB337
05-15-2005 10:16:03
THE 410 IS ANALRIGHT BALER BUT REPAIRS CAN BE EXPENSIVE FOR A LITTLE MORE MONEY YOU CAN UGRADE TO 30 OR 35 SERIES AND HAVE ALOT MORE DEPENDABLE AND USER FRIENDLY PIECE OF EQUIPMENT ALONG WITH A MONITOR WITH BALE SHAPE AND AND OTHER ALARMS TO KEEP YOUR NECK FROM HURTING THE NEXT DAY
Tx Jim
05-14-2005 04:17:23
JOA,the JD 410 is the second series of rd.balers that JD made.It only uses springs for bale tightness so it won't make as firm bales as latter models.It also lacks a monitor so one can get a sore neck using it.Tx Jim
Jason Z in MO
05-15-2005 21:17:27
 Re: JD 410 round baler in reply to Tx Jim, 05-14-2005 04:17:23
I have a mirror angled toward the bale indicators.
Saves the neck!
Jason Z in MO
05-13-2005 07:02:47
I have an older 330 and it has been a good baler. I bought it about 7 years ago for $3500.
This baler makes a nice and tight 4"x4" bale. The pick up is also 4" wide so the windrows need to be pretty narrow. I don"t have converging wheels but would like to find some.
Because you have to weave to keep the bale uniform, and without the converging wheels, it can leave some "windrow scraps". Not a big problem but I do run around an area after baling to clean it up some.
I am sold on the JD balers after looking at other bales that are loose and squat right when they come out of the baler.
