Dear all about me, your question raises some good issues regarding power requirements for portable lap tops. I used to do some power distribution design for larger main frames, but much of that also concerns smaller computers. I will try to be as brief as possible but address your concerns. STILL, all things on these volunteer boards are just our opinions remember, ask the puter manufacturer to be safe. 1) FIRST, IF the puter required much over 12 VDC on its input, that may explain why you cant by pass the inverter phase and just run/charge it direct off a car battery/cigarette lighter output. The plug in the wall adapter/charger you use to run the puter and/or charge its internal battery ought to have BOTH voltage and wattage ratings on its labeling??? That info might explain one of your questions. HOWEVER, theres more than just voltage concerns. 2) For one thing, dependign on how well the cars voltage regulation and alternators electronic circuitry works, there may be some danger in supplying potentially unstable or spike containing voltage sources into the puter. I know with the newer computer controlled cars the power is relativelty clean and stable, and the battery itself is like a big buffer, filter and capacitor, but maybe the vendor fears if you plug the puter direct into a poor quality or older auto, the raw power might be unstable or do harm to the puters sensitive electronics. 3) Now, the puter still basically runs on its internal battery (even when plugged in, that just float charges the battery) and it has some ability to filter, buffer and smooth out power spikes etc. Still however, the AC unit you plug in the wall provides yet another level of protection, filtering, and bufferign as it takes raw AC power, transforms and rectifies and filters it, then dumps it into the puter to charge the battery. 4) FINALY AND THEREFORE, the use of an inverter (12VDC to 120 VAC) PLUS coupled with the puters normal power supply (120 VAC to X VDC) may provide safer, cleaner power than if you just dumped the raw auto DC into it direct (especially if the cars started or running versus just sitting, when its raw battery power is nice n smooth. If the voltage output of the current AC to DC input device/charger is like in the 12 to 15 VDC range (but I bet its tigher regulated, and maybe slightly higher???) the DC power from a cars battery at 12.6 VDC could run/charge the puter just fine CAR NOT RUNNING. However, its the startign and switching and voltage regulating going on which the puter may not like so well and which is why perhaps an inverter could still be better. Look at the AC unit to see its power and voltage ratings. Then as you mentioned, perhaps the 75 watt inverter you bought can not sufficiently maintain the puters battery??? Theres also a HUGE difference in quality and price of inverters. Some may produce a square or a modified sine wave output while others a more true sine wave etc. Maybe a raw power device like a brush motor dont care so much, but sensitive electronics can. NOTE: I would try to contact the puter manufacturers techy people and "do as they advise" versus any pimpled nerd wannabees at a local shop or myself for that matter. Let us know, good luck n God Bless John T Nordhoff [email protected]
