4630
Robert
02-23-2004 10:56:44
I am considering buying a 1977 4630 with cab and powershift transmission. Can anybody tell me the pros and cons of this tractor. I know the 40 series are a lot tougher but they are way out of my price range. 30s are going for $12000-$15000 around here. Thanks for any help.
Mike w J
02-24-2004 06:18:18
 Re: 4630 in reply to Robert, 02-23-2004 10:56:44
The powershift is a very tough transmission in my opinion 9 out of 10 that have been overhauled have been neglected or heavly abused if serviced regular (oil filters) they will take loader abuse but don't like to be run low on oil overheated from very low oil or from low preasure the 4020 and 3020 have heat and preasure gauges not sure if the 4630 does but I think it must.
Lee
02-24-2004 00:36:56
They are defintely cold blooded, 5:00 AM in the middle of summer you will still need a shot of ether to get her going quickly and smoothly. Water jacket heater a must in winter. Ran all the hydraulic fluid out it some 4 times to a complete standstill pulling in the field, no work required as yet. That makes Powershift pretty darn tuff and hard to hurt if you ask me. Too small a fuel tank for a full days work, 80 gallons will only last 7 hours or so if you are working her hard. Perhaps the best front end loader tractor ever made? Control on that bucket is most excellent. Top heavy with only single tires on, duals eliminate that entirely. Frame rails tend to pull loose from rear of engine causing whole frame to loosen and fan hits, then breaks fan shroud. Fixed with new bolts, heli-coil kit, and arc welding the bolt heads so they can't back out. Probably not an issue unless you have and use the front end loader hard and heavy.
charles
02-24-2004 00:25:31
Look in the archives , there are masses of letters on these and 4430 's . There is one entry explaining how to test the powershift , look up 4430 in the search , they are suposed to be more reliable than the quad but more costly to fix they like them for tractor pulling so they must be tough
Hilltopper
02-23-2004 16:55:44
I owned a 77 model 4630 for about 10 years. It was hard to start in cold weather. It had been turned up to 180 hp when we got it. I do not know if this had anything to do with the slow cranking. We never had any other problems until we put alcohol in the outside duals, to gain some weight After about 2 years the powershift went out on it. It was bad about wheel slippage. It would work circles around the 4555 that replaced it. I believe if it had been left at the rated hp it would never had the problem.
johndeere_john
02-24-2004 08:05:46
 Re: Re: 4630 in reply to Hilltopper, 02-23-2004 16:55:44
In 1977 I bought a new 4630 it came from the factory with 180 horses, Deere always advertised less horse power. Never had any trouble starting , but did plug in in winter. I had this same engine in a 4430 and a 7700 combine and they were fine motors. Jon
Jeff
02-23-2004 14:46:07
The 4630 does not have A 540 rpm pto. 1000 rpm only.
mike
02-23-2004 12:32:07
if the tractor has 7-8000 hrs or more on it and the powershift hasn't been gone through it is probably gonna need it soon. pretty expensive
