38 AR Fan shaft
Marty Z
05-11-2005 22:58:49
Having trouble setting up my AR fan shaft. Is the bevel gear on the end of the shaft into the gov. spring loaded ? Can't seem to get the right gear lash. The bearing on the gov. end holds the gear way to far away from the Gov to get correct clearance. Should the bearing and bevel gear on the gov. end slide on the shaft? Mine are tight and have to be pressed to move at all.Just can't seem to get the gears to line up tight enough. This is not a gasket problem. Even with no gasket in there the gears are gapped too far. I'm thinking the bearing has to slide on the shaft and let the gear adjust itself with spring pressure. What am I doing wrong ?
Marty Z
Curtice Ohio
turklilley
05-12-2005 10:08:57
 Re: 38 AR Fan shaft in reply to Marty Z, 05-11-2005 22:58:49
I had to shim the bearing on the flywheel side of the shaft to reduce the play in the gears on mine.
Mike M
05-12-2005 06:22:08
Those gears are all pressed on. Do you have the fan gear out against the snap ring ? The governor gears also go against snap rings for placement. Did you maybe swap some parts and end up with the wrong stuff for your year ?? Also do you have the whole governor assembly case and all off the tractor so you can clamp it in a vise with the fan pointing straight up in the air ? This is the only way to see whats going on in there and set them up right.
Marty Z
05-12-2005 07:35:01
 Re: 38 AR Fan shaft in reply to Mike M, 05-12-2005 06:22:08
The bevel gear is up against the snap ring . The inner race has room to be pressed in or out a half inch on the shaft.Should it be fitted tight up against the shoulder? Because the gears are way too loose if the inner race is up tight to the gear. Never had Gov apart but had it off to inspect and clean.
MJZ
Mike M
05-12-2005 08:26:04
 Re: 38 AR Fan shaft in reply to Marty Z, 05-12-2005 07:35:01
Exactly which inner race are you saying can move 1/2" ? Are you talking about the one on the magneto drive coupling end ? Those governor assemblies are spring loaded,a spring on the right hand bearing(mag. coupling end)pushes on a snap ring in the case and against the outer bearing cup.With no shim/gaskets on the Left hand cover drawing it up the gears should get tight before the cover does. When adjusting the gears the heel or backsides of the gears should be of even height adjustable by shims under the fan and the LH gov. cover.
Marty Z
05-12-2005 22:41:45
 Re: 38 AR Fan shaft in reply to Mike M, 05-12-2005 08:26:04
Hey Mike, Look up to the new post on my newest problems. Thanks. I messed up big this time. I need help Now. Thanks Marty Z
