'39 JD-B oil change
Vickie
05-11-2005 18:32:46
I have a '39 JD-B tractor which has been sitting for 2 years with just an occasional start-up every few months. I want to change the oil-I know where the outlet is to drain it, but where or where is the inlet????? Also, what type of oil do I use in the air cleaner? Thanks, Victoria
old
05-11-2005 21:25:36
 Re: '39 JD-B oil change in reply to Vickie, 05-11-2005 18:32:46
I have a 1935 B and the manual says to use 40W oil below 95 degrees and 50 if its hotter then that and 30 when its around 70-80. I keep 40 or 50 in all year since I don't run it in the winter
Jason Z in MO
05-11-2005 20:19:07
Vickie,
Is your 39 B a hand start or electric?
For hand start the filler cap is between the instruments and the steering pedestal. It is a tall tube with a mushroom cover. It unscrews at the base.
mattd
05-11-2005 18:40:00
the oil inlet is right by the magneto. its a big cap about 2 inches big. should just unscrew and fill er' up. the oil level check plug is underneath the pulley and sticks out about 2 inches. the oil filter cap is right next to the drain plug. use the same oil in the air filter that you used in the motor. HTH
matt
