I know nothing of my John Deere B
MACE
05-11-2005 18:19:49
Howdy,
Got a 1950 B the other day and a few questions.
How many quarts of oil does it take, or is it gallons?
What is the best spark plug to use?
Did a 1950 have a 6 or 12 volt system?
Does anyone know the part # for the correct generator?
More to come,
Thanks
MACE
MACE
05-12-2005 18:36:42
 Re: I know nothing of my John Deere B in reply to MACE, 05-11-2005 18:19:49
Today I got the oil, and filter and I know just a little bit more about my JD B then I did yesterday.
Thanks for all the help fellers,
MACE
Mike M
05-12-2005 06:31:48
John Deere still should sell a very good service manual that covers that model. I would use autolite #388 plugs,6 volt positive ground system,7qts oil sounds like a good start. Just fill until it runs out of the level petcock them run it to fill the filter housing and add some more.Don't forget the oil bath air cleaner another quart. It's getting hard to find generators with tags on them I think alot of the rebuilding companies take them off and stamp in their own numbers.The JD parts book will show the correct Delco numbers.
Mike in UP of MI
05-11-2005 19:47:04
MACE
I have two 1950 B's also. Oil change is 7 quarts. Don't forget about the filter. I use Champion D21's, but sounds like D23's work better. They don't foul out as fast. It should have a 6-volt system. Both of mine have been changed to 12-volt. According to the parts manaul the John Deere number for the generator is AB4083R, Delco-Remy #1101390 and #1100506.
Mike
mattd
05-11-2005 18:34:03
oil capacity is about 5-6 quarts i think. oil filter still available from deere dealer. i use champion spark plugs, #8 i dont remember what letter is in front of the 8. 6 volt posotive ground system. the generator is a delco remy but i dont know the number. HTH
matt
