35 unstyled A head gasket
hulkmjw
05-11-2005 13:44:51
I have a unstyled A i have high compression pistions ive had the head and block checked out perfect The JD head gasket wont stay sealed it seeps on the outside i have retorqued the head cold and after i had it warm its possible that the new studs from deere are streching but this is the third time its done this i have sprayed copper spray this last time and still hasnt sealed what is wrong am i doing something wrong i torque to the same order in the IT shop manual
jas
05-12-2005 19:35:19
 Re: 35 unstyled A head gasket in reply to hulkmjw, 05-11-2005 13:44:51
Are you installing the gasket with the correct side out?
JRB
05-11-2005 16:13:10
You say you've had the head and block checked out. Did they only check for cracks? If that's all they did, then you need to have the head planed and the block "decked". This will true-up the mating surfaces. With all of this and a new head gasket, no more leaks! Good luck!
hulkmjw
05-11-2005 16:27:30
 Re: 35 unstyled A head gasket in reply to JRB, 05-11-2005 16:13:10
yeah i have had them both magnifluxed and its possible that the both block and head are not mached exact but the motor shop checked for straightness and they both were great so i dont know if its the john deere gaskets or what my compression is around 185-200PSI thanks matt
JDTH
05-12-2005 04:09:17
 Re: 35 unstyled A head gasket in reply to hulkmjw, 05-11-2005 16:27:30
Try a gasket from either Victor, Lubbock Gaskets, or Fel-Pro. My compression is just over what you're running, it's been together for 2 years the a Victor. Make SURE the deck and head are perfectly flat and retorqueafter the tractor is warmed up.
