3010 PTO: spins at 1000 won't at 540
Eric Biderman
05-11-2005 10:59:47
I have a 3010 the PTO made a weird knocking noise then it stopped turning. I took off the stub shaft so that little pin could pop out and the PTO spins fine at 1000 RPM so the clutch is fine. Do I have to split the tractor to get in there and fix it? Thanks for any help.
Tx Jim
05-12-2005 04:17:00
 Penny may work in reply to Eric Biderman, 05-11-2005 10:59:47
Eric,before splitting you can try putting a penny in center between stub shaft and main shaft.This may push rod far enough if little pin is slighlt bent not broken.If this doesn't work it's spitting time.Tx Jim
ET
05-11-2005 12:09:18
 Re: 3010 PTO: spins at 1000 won't at 540 in reply to Eric Biderman, 05-11-2005 10:59:47
The pin that shifts it into the 540 pto speed is broken. To fix it you need to split the tractor behind the clutch housing.
