4010 G
Robert R
05-11-2005 09:22:03
I am considering a 4010 G W/Loader, price is right.
What are some areas I need to look at.
I Know fluids, cluth wear..
What do blowby and weep hole weeping indicate as to immediate needs..
Other areas to look at?
Thanks...
JDBert
05-11-2005 09:25:15
 Re: 4010 G in reply to Robert R, 05-11-2005 09:22:03
Weep hole and blow by indicate the need for a overhaul. weep hole means that your sleeve orings are bad and allowing water to pass by. Blow by indicates ring/sleeve/piston wear. How bad is the blow by? You might be able to just do the orings, BUT while your in that far you might as well just do the whole thing and be done with it.
Robert R
05-11-2005 10:51:49
 Re: 4010 G in reply to JDBert, 05-11-2005 09:25:15
I was makin a general statement @ things to look for Ie blowby, weeping.
Any other general things to look for?
