750 drill
8850 dave
05-11-2005 04:06:34
Does someone make a no=till coulter attachment for the 750 drill which mounts in front of drill?
James2
05-12-2005 05:51:30
 Re: 750 drill in reply to 8850 dave, 05-11-2005 04:06:34
It appears you are not entirely happy with the 750 either. We had two one 15 ft and one 20 ft. In poorer, damp soil they would open a slot, drop seed and not adequately close the slot. Got rid of them and went to a standard 3 pt drill mounted on a coulter cart with double cutters. On another forum, I believe Successful Farming, someone showed a picture of a 750 on a coulter cart, which I believe was made by Unverferth. The picture/unit looked pretty good. The only problem I can see is that you own a premium drill and are adding more expense; ie a coulter cart, when a less expensive drill would work with a coulter cart.
Paul Winter
05-11-2005 06:08:26
Why??? been using them since they first came out will go into any thing except concrete. yetter made fert coulters to go on there so might work for you.Paul
