JD 140 LG
russ cusick
05-10-2005 20:49:02
I have a 69 140 H1 with the 10 amp alternator (14 HP Kohler K321AS). I was wondering if I could swap the failed 10 amp stator and cracked flywheel with the less expensive 15 amp stator and flywheel. I appreciate any help on this.
Bob
05-11-2005 00:49:32
 Re: JD 140 LG in reply to russ cusick, 05-10-2005 20:49:02
If I recall correctly, a 1969 would be electronic ignition, with the trigger tab cast into the outside of the flywheel, and the stator would have a coil separate of the battery charging coils to power the electronic ignition.
Do your replacement flywheel and stator have those features?
What is the actual serial number?
