1020 crankshaft
MatthewFeil
05-10-2005 18:58:18
I posted a few messages years ago on my rebuild of my 1020 diesel. Anyway, I ended up blowing the rod bearings from one of the rods through both sides of my engine block. Seems as though the bearing seized or the piston seized inside the liner. There were pieces of the liner in the oil pan when I dropped it to check.
Long story short - I now have to at least buy a reconditioned block. What"s the best way to tell if the crankshaft is still good? I looked up in under the engine after removing the oil pan and it looks like the rod broke off after the piston siezed, but the crankshaft looks good. What would damage look like? Do I need to have the crank magnafluxed?
Any help would be appreciated as always. If the crank is cracked, I will not be bothering with this and buy a rebuilt complete short block.
Bob
05-10-2005 19:22:37
 Re: 1020 crankshaft in reply to MatthewFeil, 05-10-2005 18:58:18
Have a good machine shop magnaflux the crank, check it for straightness, and check the journals. True, this will cost some money, but you can't afford to risk the $$$$ damages if anything is wrong with the crank and another block gets ruined.
