Retired, First things I would check and suspect are the carbs float n needle valve n seat assembly plus the gas shut off if it has one like at the sediment bowl. Its wise TO ALWAYS TURN THE GAS OFF like at the sediment bowl shut off or any in line shut off etc if it has one/any, cuz if the carbs needle n seat are leaking and the gas isnt shut off, it can overflow the carb n get gas into the cylinders n crankcase. If you can remove the carb bowls bottom drain plug or drain cock and insert a hose barb and a clear plastic tube raised above the carb bowl you can see at what level the float n needle valve n seat assembly are maintaining the gas level in the carb and it MUST BE SHUT OFF AND MAINTAINED AT A LEVEL LOWER THAN THE TOP OF THE BOWL, otherwise it can flood over into the manifold n cylinders n crankcase etc. Or else if with the gas turned on remove the carbs air intake piping etc. and if you see gas getting up into the throat and/or running out, its again, a float or a needle n seat problem. It may be minor with just a speck of dirt or gum n varnish clogging up the needle so it dont rise into and seal in the seat??? If you determine the float n needle n seat are not shutting the gas off a the correct level lower then the carb bowls top,,,,I would start by using gumout etc n try n clean the needle n seat area. It may be possible to remove the carbs side inlet strainer lil plug and use gumout sprayed in which may clean any gum or varnish and if that dont work remove the carbs side circular inlet strainers top nut n cap (may need new gasket) and use gumout to clean it out and at the bottom where the seat is located. If cleaning out dont make the needle n seat work and the floats NOT a leaker, the needle valve n seat may need replaced unless the lil bottom gasket is the cause??? If worse comes to worse and you have to remove the carbs bottom bowl USE CAUTION on the bottom nut. If the floats bad it never rises to shut the needle into the seat to turn the gas off. If the float makes any sloshign sounds when shook or you can hear or feel gas inside, shes a bad leaker and sinks to the bottom n needs repaired or replaced. SUMMARY: If the gas level in the bowl rises over the top n floods the carb and engine, I first suspect the carbs neelde n seat may be clogged or has gum n varnish not allowing it to shut the gas off which a cleaning with gumout may cure. If the floats bad n leaks it needs repaired or replaced. If the fooats good and the needle n seat are good but she still overfills the bowl, I suspect a bad gasket in the seat assembly or the carb may even be rusted and porous at the bottom. Thats all I have to say about that, lemme know what you find, good luck n God Bless Ol John T in Indiana
