Caroni finishing mower behind my 60
Tom in NE PA
05-10-2005 15:00:52
Can anyone "dime" in with some experiences or advice concerning pulling an 84" Caroni mower behind my JD 60. I've gone through the archives, and there isn't much recent info. I'm considering making an offer on this mower to pull behind my machine.
Will the Caroni gearbox handle the power of the 60?
Thanks in advance
TOM
Mike M
05-10-2005 18:36:56
 Re: Caroni finishing mower behind my 60 in reply to Tom in NE PA, 05-10-2005 15:00:52
I would check out a Landpride brand.
mark
05-10-2005 18:12:42
I've owned a Caroni 60" finish mower for 20+ years. In that time and hundreds of acres of grass, I have replaced the deck once, one spindle, and one seal. I have litterally beat it to death and it just keeps on going. I just bought a used Woods 660 to replace it and from what I see, I downgraded. The Caroni has a very simple belt tension set-up, not the Rube Goldberg spring tension on the Woods that takes 3 arms and a midget to replace the belt. I always used Caroni brand replacement blades and I feel they are too soft, compared to others I have seen. The gearbox on the Caroni is stout, never had a minutes worth of trouble from it. I ran it at first with an Allis CA and then with a JD 1050. I just bought a new JD 5320 and I'm sure it'll work just fine with it. I'm a notion to buy another new deck and sell the Woods. The Caroni also runs a lot quieter than the Woods...perhaps due to blade design.
John Van Valkenburgh
05-10-2005 16:56:39
I pull a 72" Caroni finishing mower behind my 50 without any problems. I keep the engine speed up and run in 3rd or 4th gear. This gives the blades enough speed to do a nice job. I have not had any problems with the Caroni gearbox although I have had the center spindle loose a bearing. Overall I was not impressed with the bearings that they used in the spindles but properly greased, they appear to be sufficient.
I tacked a short piece of steel on either side of the mounting hole on the blades. Other than a ribbed washer there is not much that keeps the blades from spinning on their shafts. There are 2 schools of thought here. First, if you hit something especially hard it would be beneficial to have the blade "slip" to deaden the shock. On the other hand, I found that the blades would loosen and slip a little too easily and so I added the steel channels to keep them locked in place. The slipping might be less of a problem if a new nut is used each time. I seem to recall these are nylock nuts.
The estate mower does take a beating. I use it to mow pastures where I really should be using a bush-hog. Overall I would rate the mower as "Good".
Best of luck,
John
1953 Model 50
Tom in NE PA
05-10-2005 17:57:02
 Re: Caroni finishing mower behind my 60 in reply to John Van Valkenburgh, 05-10-2005 16:56:39
John,
Thank you very much for your reply. If I purchase this mower I will take note of your blade suggestion.
TOM
