JD 950 - brake shoe/cam pivot plate removal
Bill Wylde
05-10-2005 12:45:54
I have a late 950 2WD with a sticky brake problem.
The brake arm, which I assume to cam the shoes does not move and the whole unit resists removal.
The brake linkage has been removed, as have all bolts attaching the cam plate to the rear-end housing.
TIA for any help in removing this brake?
Bill Wylde
05-11-2005 14:27:56
 Re: JD 950 - brake shoe/cam pivot plate removal in reply to Bill Wylde, 05-10-2005 12:45:54
Gentlemen:
The beast is out of its cage. What a seige it was!
Thank you very much for the returns.
Joe M (GA)
05-10-2005 17:14:51
they love to rust up tight! Keep spraying with PB blaster or Kroil. Tap the housing lightly with a deadblow or rubber hammer. It will come off, just takes time. Start saving now for your brake shoes, best I remember it"s around $200 for four shoes
mark
05-10-2005 18:17:51
 Re: JD 950 - brake shoe/cam pivot plate removal in reply to Joe M (GA), 05-10-2005 17:14:51
I had a 1050 for 23 years and relined the brakes once. I bypassed the JD dealer and sent the shoes to a brake shop that glued new linings on for less than $30.....about 10 years ago.
I never experienced any trouble removing the housings and i had them off a few times. You can turn the shoes over once as they tend to wear on the cammed out end first. That was my biggest gripe with these series tractors...that and no power steering. If they'd used wet brakes and hung PS on all of them, they would've been a perfect small tractor.
