JD 4000 turbo???
PJBROWN
05-10-2005 09:50:46
I liked reading the facts about the 4000 vs. 4020 in a earler post. I have been thinking.... has anyone ever seen a turbo on a 4000 ???? That would be good power to weight ratio. What's a 4000 stock 96 HP ??? Maybe with a turbo you could get 115 Hp ???? . That would be like putting a 4320 engine in a 3020.
Mike w J
05-10-2005 12:09:42
 Re: JD 4000 turbo??? in reply to PJBROWN, 05-10-2005 09:50:46
Ihave a 1969 4000 and my dad has a 1970 4000 his has 13500 hours on at 60 hours it pluged an injector it was repaced and dinoed 116 hp at 11500 under heavy load it had a rattle They dinoed it again find where the noise was coming from and it had 118 but the rattle ended up being a broken wrist pin They just wanted to replace the wrist pin and 1 piston we thought that was a joke so they did a complete major including then new style pump it had the roosa master model CB pump my son going to votec took it to put a clutch in it the 3rd one since new dinoed it again and it only has 102 hp. it has no turbo and never did but I must say When dad found out it only had 102 he was very dissapointed and wanted it turned back up He is 74----- -- I say 120hp won't hurt it if you take care of it and keep transfluids full and clean
WTW
05-10-2005 12:29:41
 Re: JD 4000 turbo??? in reply to Mike w J, 05-10-2005 12:09:42
Mike, The reason your HP dropped was most likely due to your injection pump upgrade. It was the right thing to do for longevity but this was a common result. The old C pump run like crap idled very poor sounded like they were missing but under load they did in most cases produce more fuel / HP than the DB will. It can be adjusted up to achieve what you had but will require a pump adjustment. DW
WTW
05-10-2005 11:37:29
Nothing 3020 about the 4000 other than the cast wheel centers if it had 38" rubber. 95% of the parts on the 4000 tractor are the same parts as the 4020. Reference a parts catalogue for clarification. The 4000 would run for ever at 125HP with a turbo. I know of some that run more than that. Really the only thing lighter in the rear final drives in the 4000 over the 4020, 4320, 4230 or 4430 was the smaller diameter axle shaft. The 4000 final drive sun R45779, ring R61176 and planetary gears R33004 are the same parts as what the 4020, 4320, 4230 or 4430 came from the factory with. The final drive carrier is special (not lighter) on the 4000 to adapt to the smaller unique 4000 axle shaft. You won't hurt the rear end in a 4000 with 125 HP. DW
JDBert
05-10-2005 10:48:31
You wouldn't have enough rearend to take the power if you really wanted to pull it all day long.
G/MAN
05-10-2005 10:39:29
It's completely possible, and I'm sure it's been done many times, since the 4000 and 4020 engines were pretty much identical. JD parts catalog PC1116 covers both the 4000 and 4020, as a matter of fact. An M&W kit would bolt right on a 4000 same as a 4020, as far as I know. 120 hp is about as far as I'd be willing to go on one, as the lack of piston-cooling nozzles in those engines is a drawback. You'd have 4320-type horsepower, but nowhere near the engine, as the 404 used in the 4020 was upgraded substantially to become the "Turbo-Built" engine used in the 4320.
